Im replacing both of my pan gaskets. Oil filter housing gasket. Timing case gaskets. Output shaft seal. Transmission Fluid.
Here is a list for my318is (m42 car and getrag 240) any other seals I should do or could do easily?
just a list from BMA (not sure if Ill buy it there)
Output shaft seal -3$
Oilfilter housing seal -2$
Upper/Lower pan gaskets 15$ 7$
Lower timing case gasket set (2 piece) 14$
Upper timing case cover (3 piece) 6$
plenty of RTV silicone to seal them as well.
But if i missed something you think i should do let me know.
