Help a NOOB find the right thread...
    My RPM and MPG needles gave out. All I found was some write up on switching the gears on the odometer part. nothing on troubleshooting the rest of the cluster.
    Any hints and tips? good threads to check out ?
    09/1989 325i 4 Door
    +M30 Swap
    +Z3 Steering Rack
    Either replace the:
    tach unit
    SI board
    coding plug
    entire cluster
    No matter what the best way to do it is to buy a spare cluster and either drop the new one in or steal parts from it.
    -Alex
      if ur radio died too, it's a dead fuse.
      the speedo and tach was acting up on a freinds eta we swapped the whole cluster and now it's 100% better!
      Originally posted by e30e
        SWEET!!!
        my radio died as well.
        Which fuse shall I inspect bimmer_E30? vielen dank!!
        09/1989 325i 4 Door
        +M30 Swap
        +Z3 Steering Rack
          where in sc are you?
            Greenville/Spartanburg, live in greer. I'm guessing you're in Landrum ?
            09/1989 325i 4 Door
            +M30 Swap
            +Z3 Steering Rack
              I believe its fuse 12. a 7.5 amp fuse
              PSN ID: Yourself1
                Nope, Landrum's my name - Travelers Rest area, 'bout to move out near lake robinson on monday though.
                  Thanks ! I'll go check it right now....
                  09/1989 325i 4 Door
                  +M30 Swap
                  +Z3 Steering Rack
                    usually when the tach and mpg dies or starts to act up, it's your SI batteries. i replaced mine and everything works now.
                    TIP: when you service lights comes on, reset it. i think this is what got my batteries because i didn't reset the lights for 2 years :D
                    1991 330is
                      Originally posted by Heysüß View Post
                      SWEET!!!
                      dont remeber which one it was but read the manual it should tell you.
                      first thing i did on my old eta lol, died on me that sucker. :p
                        yeah, i just got the car so my bentley is still in shipping. thing cost me 52 bucks cause I needed one that covered the M30 not the M20, the stock E30 bentley was 35 on turner, you lucky dogs you.
                        09/1989 325i 4 Door
                        +M30 Swap
                        +Z3 Steering Rack
                          did you find the fuse?
                          PSN ID: Yourself1
                            well fuse 12 seemed fine but i still replaced it and no go. still no radio, RPM, or MPG. there was another fuse at the bottom of the square (can't remember the number) also a 7.5 that was burnt out so i replaced that one. if i have time later i may just go through and check each one.
                            09/1989 325i 4 Door
                            +M30 Swap
                            +Z3 Steering Rack
                              it's fuse 21. had the same exact problem the other day. 7.5amp
