Driveshaft bolt
  • 1989e30325
    • Dec 2009
    • 124
    Driveshaft bolt
    Im missing one of the 6 bolts that connect the flex disc, and i was hopping i could go to the store tomorrow to get a new one, i dont really want to order it. Does anyone have the specs of the bolt? Or know the size or anything?
    Im hoping this will fix the vibration problem im having.
  • Need4Speed1299
    • Oct 2007
    • 119
    Pull another one of the bolts out and go to a hardware store. Be sure to get the same strength bolt and nut as the OEM one.
    • 1989e30325
      • Dec 2009
      • 124
      Problem is i cant get another out because the driveshaft cant be locked up because i dont have an e-brake. Otherwise i would...
      • Adrian_Visser
        • Jun 2006
        • 2823
        Get the right bolt! Or find the one you lost what are you going to do go to home depot and buy an 8.8 bolt? I tried to find a place that sold automotive grade hardware when I was sick of dealing with the retards at my local dealership I had no luck.
        '89 Alpine S52 with goodies
        • 1989e30325
          • Dec 2009
          • 124
          So i shouldnt go to a hardware store or deal with the retards at the dealership? Did you buy it online? What website?
          • Edev
            • 3731
            Kuni would be the closest to you. Bolts are wicked cheap. Tell them what year and model it is, then what you need it for. They'll pull up a picture and show you it to clairify it. Bam. Done. They should have it in stock. If not, Rasmussen (A little bit North of Kuni) should have it in stock.
            M Coupe
            • 2002maniac
              • 4260
              Off the top of my head it's M10x50
              but don't trust me, look it up.
              • 1989e30325
                • Dec 2009
                • 124
                Thank you all!
                • lennon
                  • Jun 2008
                  • 1416
                  Parts catalog is your friend... they are indeed m10x50. You need the proper self-locking nut too. I would just buy OEM from dealership or Blunt or whatever online method you choose. Get the right thing and save the hassle.
                  • NC325iC
                    • Mar 2004
                    • 6565
                    put it in gear to get another one out.
                    • Burnera
                      • 137
                      mcmaster.com also. They deliver within a couple days if you can't get your car moving.
