Install Prices
  • Will_318i
    • Jan 2010
    • 482
    Install Prices
    So I called a few shops around my area to get prices on installing a set of struts/shocks, lowering springs, front brake pads and rotors and the wear sensor. I got quoted $300 from one place. Doesn't that sound a bit absurd? I called another place and got quoted $180 which sounds more reasonable. I know it depends on the shop, but that $300 seems like a bit much.
    So my question is, for people that went to install shops to get something like this done, how much did you pay?
    Thanks.
    "get in, get off, wipe your dick off on her sheets and get out."
  • StereoInstaller1
    GAS
    • 22679
    I would say 3 hours isn't out of line for that
    Closing SOON!
    Thanks for 10 years of fun!
    • ak-
      • 12422
      Do the brakes yourself!
      I can understand not having a spring compressor though, if needed.
      1991 325iS turbo
      • Naplm00
        • Nov 2008
        • 1573
        in jersey you would have been quoted $900
        88 325ic ~~~> Rusty and ugly
        85 E ~~~> RIP
        • dannyyisntt
          • 3141
          it's like a $30 dollar deposit to rent a spring compressor
          • E30_(1st Musk)_
            • 2008
            Thanks.
            i say you do it yourself! Go to the autozone on sherman way/variel they do a $50 deposit loan for the spring compressor. If you decide to do it yourself pm me i could help you out. im always in canoga
            • Adrian_Visser
              • Jun 2006
              • 2823
              Easy job to do yourself. Maybe consider getting a balljoint tool as well just in case. One similar to this:
              The collar nuts on my struts required the use of a 3' pipe wrench and alot of heat to break loose so I would keep that possibility in mind. Rental on a spring compressor and buying a balljoint tool and (if needed) a big ass pipe wrench is much less than the labor costs will be plus you might learn something.
              '89 Alpine S52 with goodies
              • ///digitalme
                • Dec 2009
                • 2088
                wtf seriously!!!?? i got both front springs, shocks, strut mounts, rotors replaced for 90 bucks.....i wouldnt pay more than 200 for all 4
                • ethree
                  • Aug 2007
                  • 1216
                  I'd bet the book is probably four hours.
                  You can always find some hack to do shit for half price I just don't want that dude touching my vehicle.
                  • einstein57
                    • Jun 2007
                    • 10780
                    Just pay me to do it. I'm cheap and efficient.
                    www.gecoils.com
                    • Will_318i
                      • Jan 2010
                      • 482
                      thanks for the responses guys. The shop that quoted me the $300 is a shop that gets alot of love on the forum here. And the one that's $180 is a smaller shop but gets a bit of love here too.
                      Don't get me wrong, if I could do it myself I would. My dad just took a month long trip to the Philippines and he was the guy I was going to do it with. But with him gone for a month, I don't want to wait till then.
                      • StereoInstaller1
                        GAS
                        • 22679
                        reacharound with full suspension?
                        Closing SOON!
                        • Wh33lhop
                          • 11705
                          Here's how I separated the ball joints (needs 2 sledges)
                          Jack the car up, jackstands etc. Unhook the sway bar and unbolt the upper strut mount, let it drop down and towards you.
                          Loosen the ball joint/tie rod nuts, position them at the top of their studs so there are no threads showing. Support the bottom of the strut with your jack so it's braced against something.
                          Take hammer 1 (I used the smaller hammer, a 2lb sledge) and position it on the top of the ball joint/nut. You are going to hit this one with hammer 2 (I used a 4lb sledge) and it will deliver the blow to the ball joint. It's easier to aim for a hammer than a ball joint. I was able to separate everything (2 ball joints, 2 tie rods) without tearing any boots or doing too much damage to the nuts (they went back on fine, you can always get new ones anyway).
                          As for the front springs, rent compressors. The rears will come out if you unhook the swaybar and the axles, no spring compressor needed there.
                          paint sucks
                          • accident
                            • 7303
                            have you called the Castros?
                            Moral of this story?
                            • Aptyp
                              • 6584
                              Around NC, if you go to shops you'd be paying more than $300... You'd pay $160 for brakes alone if you go to a quality shop.
