Dem strange Germans. WTF were they thinking?
Fuel Cooler (BMW OEM)
Resurrecting this old thread, since last night I had the same WTF moment... But also had an interesting thought...
Now, what if the supply side ran through the cooler instead of the return? Any benefit of cooling the fuel before it got to the injectors? Or would any (probably negligible) power increase be negated by the fact the A/C pump would be running?Ben
Thelma-Louise, the '88is Chump Car - back to M20 power!
2014 ChumpCar Season Schedule!
April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
May23-25 Watkins Glen, NY: 4th, 5th, 4th
October 4 PittRace Sprints: 2nd in C-class
October 18-19 NCM, Bowling Green KY: 2nd, 1st!
Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
Find us on FB! Schaut Speed MotorsportsComment
My e46 323i has something called a 3/2 way valve, that actually sends fuel back to the tank, right after the fuel filter. Same principle, gotta keep that gas from warming up.
http://www.realoem.com/bmw/showparts...37&hg=13&fg=10Supatek -noun - your basic know it allComment
Now, what if the supply side ran through the cooler instead of the return? Any benefit of cooling the fuel before it got to the injectors? Or would any (probably negligible) power increase be negated by the fact the A/C pump would be running?Comment
^ exactly, you would want to do the exact opposite. Warming to fuel would lead to better atomization out of the injector and therefore lead to a more efficient and powerfull burn.
Case in point: many jet engines have a 'liquid to liquid cooler'. Essentially it is a radiator with tiny fuel lines running though a larger oil case. The fuel on the way to the injectors cools the oil while at the same time being warmed by the oil which is on its way back to the sump.Comment
