Gotta change 5spd trans on m42, Clutch questions
  • wastedincome
    • Aug 2004
    • 906
    Heya all, Been a while since on here since I've been lacking on treating the e30 proper. I'm inorder of replacing the trans in the due to the fact I lost 2nd gear a while back. SO, I figure that I should also replace the clutch @ the same time. I've done a lil research (as,I've been outta the e30 world for a bit due to the e34) there seems to be a dual Vs. single mass flywheel thing on the m42?!?! Whats better??? I have held reserve plans of upgrading to a I6, But in the mean time I wanna keep the m42 running strong. Whats the "best" clutch kit to go with??
    Wastedincome420@yahoo.com
    CURRENT STOCK LIST:
    00' e38 750iL HighLine=Highway Queen
    92' e30 318 vert=Aint going anywhere
    91' e34 535iM=Aint going anywhere
    91' e34 525iA=For parts
    92' e34 535iA=For parts
  • Mossman
    • Apr 2006
    • 1961
    There wasn't a single mass m42 flywheel that I know of, people swap m20b25 (325i) single masses, clutches, and pressure plates in. You'll need m20 starter and a special throw out bearing I think from an e21. There's an m42 specific forum here, and http://www.m42club.com/ between those two places you'll be fine
    • decay
      • 5637
      there is an m42 single-mass flywheel; it was used in non-AC cars and I don't think you could buy an e30 that way stateside. i have one on the way from germany right now.
      past:
      1989 325is (learner shitbox)
      1986 325e (turbo dorito)
      1991 318ic (5-lug ITB)
      1985 323i baur
      current:
      • Julien
        • 7471
        I had one of those in belgium.. what a sweet combo a non-a/c, smf 318is is
        Build Threads:
        • Zacm829
          • Jan 2008
          • 1919
          I have a 325i single mass flywheel and clutch setup for sale at the moment. Let me know if your interested.
          1987 325i-M60b44 swap
