1987 325is
Alpine White/Black Interior
175k miles
5 Speed
CLEAN interior/exterior. No dents/dings on the outside. Little 1/2 quarter size rust bubbles around rear window (on side of window). Paint in very good condition. Interior is in VERY good condition, no holes or rips in leather.
Runs good, drives straight. Has a very slight hesitation down low but nothing a tune-up shouldn't take care of. This could have also been caused by the intake boot being just slightly loose (after the MAF) which was discovered after the car was taken for the test drive.
Problems/Issues:
Wiper motor/switch - Windshield wipers dont work, dont even try to work at any speed (sand in the reservoir so they haven't for a while Im assuming).
A/C Blower Motor - A/c works and blows COLD but the blower motor makes a hellacious squeeling. Works but needs new motor.
CD Player - Aftermarket Pioneer CD player that doesn't pick up any statations. Rear antenna is broken off so that could be an easy fix but not sure.
Central Locking System - Comes with 1 aftermarket key that works 1/2 the time in the doors. When turning the key all the way to the right sometimes it will lock, sometimes it wont. Sometimes it gets jammed in the locked position and wont come out, sometimes it locks fine. Takes a good couple of minutes to lock the door.
Cruise Control - Not working, don't know why.
Sunroof - Opens fine, on closing sometimes gets caught about 3inches from closing all the way, a hand pushing it along at that point and it closes find. It doesn't tilt upward on position 2 though.
The engine oil light is also being thrown on the OBC. It is also at inspection time according to the OBC (in red/yellow area with either 1 or 2 bars left), will this cause the engine oil light to be thrown? Oil level does not appear to be low when checked. Windows work but passenger side goes down until its about 1/4 inch from the bottom. Its barely poking out of the doorsill but you can tell its not all the way. On the way back up it goes all the way up but makes a sound when it hits the top, almost like the window motor is still trying to push the window up even though its all the way there.
No history on the vehicle. Fuses were checked and all in-tact so the issues aren't fuse related (unless they're relay Im not sure). Tires are ~30%, driveable but need attention within the next few thousand miles.
What would you guys expect to pay for it? The vehicle is CLEAN in/out and the motor runs good, it just has a few things it needs worked on and I wouldn't have any problem driving it long distance from what Ive seen. Trying to see what you guys think it's worth under these circumstances. Its just a little more than I budgeted myself to pay so I wanted outside opinions before I make a decision on it.
175k miles
5 Speed
Problems/Issues:
