OK so I have a bit of a problem, with Massive front strret kit (corrado rotors) which are a bit thicker than standard rotors I can not put spacers on the front. I had some 10mm hubcentrics and there wasnt enough meat on the hub for the wheel to sit right and be true, got some 10mm w/ the hubcentric rings built in and they cracked the ring right off because there was again no meat on the hub for it to sit and taking all that pressure and impact on the ring with really nothing behind it killed it. So does anyone have a solution for this? Lee? any feedback?
Massive front street kit w/ spacers?
