Finally after al the problems with the 325i. three head gaskets and a set of head bolts it finally turned out to be a cracked head through the number 3 and 4 cam jurnals. I piced up a 190000 mile head friday, dissassembled it, ground the vallves, recut the seats, milled the head flat, lapped in the valves Sat. Put the head back on Sunday and broke 2 blue metric bolts at the 60lb/ft torque step. Broke one removed the head again got the bolt out, put it back on, and broke another bolt at the same step. So I got another set up factory bolts and got it torqued down. While putting the timing best cover on the 6mm bolt broke off in the front of the head. I had to drill it out and retap it. It is now finally over and running. Everything seems to be ok at this time. My $300 car is starting to get into my pocket. I am now at about $1300 with the engine rebuild, extra gaskets, bolts, new interior and on and on. I dont know how much longer the old auto tranny is going to last so I am accumulating the parts to make it a 5speed. Will post pics soon.
Back in teh saddle again, finally!
1990 E30 325ic (sold for more than I paid for it after 5 Years)
1995 E30 325e (in progress)
1987 E30 325is (totaled)
1990 E30 325i
1991 E30 318is M50 PWR
1996 E36 328ic
1997 Z3
2006 F150 Super Crew 5.4L 6.5' bed The work horse (need something to drag all these old BMW's home for resurrection.)Tags: None -
Take it easy on the bolts man. That many breaking bolts is more than a coincidence.Comment
I used two different torque wrenches on the blue metric bolts just to make sure. They had been used once so I think that may have had something to do with it. The recomende 80lb/ft of torque is a little high in my opinion for that size bolt. The 6mm bolt in front of the head had very little pressure on it. I have driven it for 2 days now with no problems. Fingers crossed.sigpic
1990 E30 325i
1996 E36 328ic
1997 Z3
2006 F150 Super Crew 5.4L 6.5' bed The work horse (need something to drag all these old BMW's home for resurrection.)Comment
1990 E30 325i
1996 E36 328ic
1997 Z3
