MPG gauge acting weird
    I don't know if anyone has experienced this problem but my MPG gauge is acting weird, it keeps on going from one side to the other even if the car is in neutral. It has a swapped cluster... Anyone experience something similar?
    is the car stalling....you may have a vacumn leak though.
    M3 springs w/bilstein hd's, IE 22/19mm sway bars, front IE stress bar, complete suspension rebuild, IS interior.
    Crew chief for BBQ2U Racing: James Crivellone, John Parker, Chris Anderson, Ben Wilson, George Howe, Will Kellog, Jim Cissell
    BBQ2U Racing, Best of Intentions Racing
      Mine only works if you unplug the batt then plug it back in.. then it only works about
      5-10mins then dies...
      no leak that I know of...ugh
        no, car does not stall. MPG gauge worked today, but yesterday it was flipping from one side to the other. Today I notice the fuel gauge sometimes showing full sometimes showing half empty.... could it be a sensor of some sort or just a bad cluster.
        I should mention that the odo is not spinning even though the rollers have been replaced...
        any help?
          How is your idle? When i cold start my car and the idle is fluctuating sometimes the gauge bounces back and forth.
            idle is a little rough. Haven't tuned it up after purchase. But the gauge was acting weird after about 10 minutes of driving. I'm guessing its just a bad/dirty contact. Ill open her up over the weekend. Clean the contacts see if that helps
