Stiff Pedals...
    Stiff Pedals...
    as ive previously stated, i just bought my 2nd e30 withing the past month.the gas pedal with the new one is so much more stiff!! i have to press a little harder to get it to go. is there a fix for this?!?!?!?!!? pls fill me in. THANKS!!
    Yes, there is. It has a throttle body right? Srry I'm kinda new to e30's so bare with me. The throttle cable return spring could be a little tight and it can be loosend.
    Originally posted by devon.818
    low key i actually paid attention to the drifting...then saw bouncing tits and went :o
    as for a 4hr boner...idk, start using it for things; cup holder, dial the phone, type with it, fix things, diagnose the e30, probe random shit...
    Originally posted by Mercury[BKM]
    ...because Machine Gun
      or lubed. The throttle cable could also be rusted internally causing it to bind against the rubber protective sheeth
        needs a new throttle cable $37 bucx
          SWEEEETTTT... thanks fellahs.
            also, spray some throttle body cleaner right on the butterfly and open and close it while you spray it. It wont want to start for the first few cranks so don't be scared when it doesnt want to crank over.
