I'll have everything out in the rear next week. Should I grind everything down to bare metal, seal, primer, and spray new undercoating on or just wash, scrub it down real good and repray? Time is a little bit of a factor, but I like to do things right. Would going to to bare metal be a waste of time?
undercoating
I would suggest adding the undercoating. thereisnoyun and I just got done doing our subframes. We built an electrolysis tank out of cardboard and drop cloths which was really easy. We de-rusted everything and cleaned them up. I took a wire stripper to them (on my angle grinder) and then primed, painted and coated them. if you have the time I highly suggest do it right. I now have brand new subframes!
In the handful of times ive done this, ive found it best to use Duplicolors truck bedliner. Works great for the lower rear valance and rocker panels too. Any actual undercoating product ive used either turns out too stinky, too clumpy, or brown.
Oh, and just pressure wash, dry and spray on. If no access to a pressure washer, degreaser, bristle brush and hose off should be fine too.turk@gutenparts.com
Originally posted by JandersonProperly placed zip ties will hold bridges together.
I shouldve added, before i sprayed with the bedliner, i attacked all spots of rust, or any area that could possibly startto rust, with POR 15 first. Just as added insurance since the any bedliner or undercoating will eventually wear out from road debris. The POR15 insures that at least the rust wont spread.
You can see here @ posts # 100 and 111 : http://r3vlimited.com/board/showthread.php?t=154159turk@gutenparts.com
I'd just do it, especially if you have them out the car. ten more minutes VS doing it again.
just do it.
NIKE.1991 325iC - Mauritsblau sumthin metallic blue. DEAD
1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
1991 325iC - Calypsorot Metallic
1994 540i - Granitsilber
Originally posted by scabzzzzI've had blunts cock in my mouth, but I'm not gay.
