alright guys, i'll produce a photo of this tomorrow but in the mean time....the drivers side c-pillar is starting to exhibit clear coat failure. i'm not looking to "fix" this, i just want to stop it from spreading and getting worse. i've heard of using a razor blade to scratch off the bad and 1500/2000 grit wet sand. any ideas?
early stages of clear coat failure
Tags: None
My c pillars did that as well, I wet sanded with 2000 grit and then buffed the shit out of it. It looks better.. kinda. Its not peeling anymore though, you'll end up sanding a lot off because you've got to sand all the loose clear off. Mine went from a 2 inch area to about 8 inches.Comment
Do this or have some clear sprayed again.My c pillars did that as well, I wet sanded with 2000 grit and then buffed the shit out of it. It looks better.. kinda. Its not peeling anymore though, you'll end up sanding a lot off because you've got to sand all the loose clear off. Mine went from a 2 inch area to about 8 inches.
You shouldn't just reclear it - you should sand, repaint, then clear.Comment
You cant really polish the metallic base of a 2 stages paint. Thats why there is clear coat.sigpicComment
