God damnit...
  • mamzak
    • 883
    God damnit...
    So I'm just about to install new sway bar links in the rear, and I notice the ones BavAuto sent me are the 12mm ones, not the 14.5mm ones for the M-technic suspension cars like mine. However, it appears Bavauto only sells the 12mm ones, even if you select your car to be an M3. Wtf?
    Should I just cram the 12mm ones on?
    Also: Does anyone have the part number for the 14.5mm sway bar links in the rear? Checked realoem but they only list the 12's as well. Bah.
    All girls fuck but not all girls fuck around with combustion engines.
  • Wh33lhop
    • 11705
    I think you mean bushings, not links.
    paint sucks
    • mamzak
      • 883
      Well, the links themselves look the same, but there's no way in hell I'll be able to push the 12mm rubber bushings onto the 14.5mm bar. I went to the dealershit today too, and they didn't have a solution for me. FAaaaaaaaaaaaaaaaaaaaaaack.
      • george graves
        • 19986
        You can fit just about anything into anywhere with enough lube. Blunt taught me that.
        Speaking of that old turd, I bet he sells them for a real good price.
        Originally posted by Matt-B
        • der affe
          Technical
          • Dec 2005
          • 8452
          astroglide will do the trick!
          • bear
            • Jun 2010
            • 191
            drill em out and hammer em on
            91 325ic
            85 528e
            92 325i
            86 535i gone
            92 325is gone
