crank position sensor located.......
  • e30_Drift_Spec
    • Dec 2009
    • 74
    hey there guys!!
    im having trouble with not being able to start the car!
    I knew it was the crank position sensor!!
    but the question is simple!!
    which of the 2 sensors on the tranny is the cps cuz they are both the same!!
    the one on top or bottom!!
    i got these at a junkyard and need to find out if it is the problem!!
    thanks!!
  • Sirotto
    • 317
    Is you car a ETA or I. If it is an I it is, well on the crank atthe front of the engine at about 10 o'clock. If it an ETA it is in the bell houseing.
    "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." - Winston Churchill
    "People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
    • e30_Drift_Spec
      • Dec 2009
      • 74
      my car is eta!! but there is 2 sensors on the bell housing!!
      And both are the same!! so which is which!!
      • Atreus
        • 1846
        why are we yelling?!
        what year is your car?!
        have you checked realoem or your manual?!
        realoem is here! http://www.realoem.com/bmw/select.do?kind=P&arch=1
        1991 325iC - Mauritsblau sumthin metallic blue. DEAD
        1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
        1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
        1991 325iC - Calypsorot Metallic
        1994 540i - Granitsilber
        Originally posted by scabzzzz
        I've had blunts cock in my mouth, but I'm not gay.
