Diff. Number
  • aaron_silva
    • 1785
    Diff. Number
    I was under my car looking around and checking stuff out and I looked at my tag on my diff. It has the number 4.27 XXXX. I was wondering if someone could explain what the different ratios mean in terms of performance. Is this a good diff for the m42?
    I really do not know the concepts behinde the different ratios/number. What do they really mean?
    TIA
    Aaron
  • Rob
    • 8166
    EDIT- For every 4.27 turns of the driveshaft, the rear axles turn once [thanks franz]
    by the way, is your diff an LSD? If so, can I have it? :P
    BEERTECH
    • franz
      • 631
      Originally posted by Rob
      http://auto.howstuffworks.com/differential2.htm
      for every 4.27 turns of the rear axles, the driveshaft turns once. I think......
      The other way around. 4.27 will give more torque and more revs for any given gear/speed combo.
      • aaron_silva
        • 1785
        Rob, sorry it is open. If I remeber correctly the diff number would say LSD also.
        • Rob
          • 8166
          corrected* myself franz.
          aaron, no worried. I think the tag would have said 'S 427"
          BEERTECH
          • Super Eta
            • 1884
            correct myself franz.
            You are correct if it was an LS it would say either S 373 or in your case S 427.
            • aaron_silva
              • 1785
              So, final consensus, a 4.27 is good...bad...for my application (m42 motor)?
              • franz
                • 631
                good for acceleration, a little bad for mileage and high end speed
                do you have a cabriolet?
                If so, that was stock. If not, it's an upgrade.
                • Rob
                  • 8166
                  1991 318iC
                  stock equipped.
                  I'd imagine finding a 4.27LSD is not easy....
                  BEERTECH
                  • 808BMW
                    • 2910
                    1991 318iC
                    stock equipped.
                    I'd rather have a large case 4.10 LSD :P
                    Unless this is large case (I'm assuming not)
