ABS brake pipe
  • RobertB
    • Jun 2007
    • 244
    ABS brake pipe
    Are the M3 front brake ABS pipe the same as the regular E30' I was thinking of pulling out some used ones. Or shall I just buy some new ones? I've read that some new pipes are not exactly the same and will need some bending.
    E30 M3
    Front ABS Brake Pipe
    01 Pipe M10/M10-886MM 1 34326755597 $10.03
    02 Pipe M10/M12- 603MM 1 34512225867 $19.29
    03 Pipe M10/M10-940MM 1 34326755600 $8.65
    04 Pipe M10/M10-2074MM 1 34326755651 $10.03
    05 Pipe M10/M10-829MM 1 34326755594 $8.65
    06 BRAKE PIPE BRACKET 1 34321155787 ENDED
    06 Spacer, 4-way 1 34326777692 $0.38
    07 BRAKE PIPE BRACKET 3 34321155786 $1.43
    Thanks,
    Robert
    __________________
  • AndrewBird
    The Mad Scientist
    • 11897
    New ones are the correct length, but have no bends and come as a straight tube with fittings on each end.
    According to RealOEM, they are all the same except #2, even though their diagrams are identical.
