Heat at idle, No heat at high rpms Help!
  • ZekeTheSneak
    • 1562
    Just put in a new motor in my e30, I believe the Hoses are hooked u properly but there is heat at idle but none at high rpm. Help?
  • FredK
    • 14761
    You have reversed the heater core inlet and outlet hoses.
    • Danny
      • 14216
      See now when I did this it did it for a small time and then my heat worked at high rpms after about 3 weeks.
      And now I have a small leak inside the cabin at the heater core pipes :|
      Switch them.
      • 87e30
        • Jul 2008
        • 5676
        My heater would work initially then no heat would come out.
        Switch them.
        I just hate everyone.
        No need for discretion.
        • ZekeTheSneak
          • 1562
          thanks i will when possible, Anyone have a layout or diagram of the proper flow? I searched when i installed and found nothing.
          • 7pilot
            • 475
            Back of the head to the bottom pipe on the firewall.
            m
            • z31maniac
              • 17566
              Just take the two coolant pipes that go into the firewall and switch them.
              Simple as that.
              www.gutenparts.com
