Well, Its been an intermittent problem. Half of the time, it will start, and the other half it will just crank forever and ever. I dont get any power to fuse 11 or whatever the fuel pump fuse is. So I assummed it was the relay, because when I would turn the key to 2nd position and listen to the relays, they sounded like they were spazzing out(repeated clicking).
So I swapped the relays with ones from my vert, and it got it started, but when I brought it home(this is taking place from a couple weeks ago when I was bringing the car home from bodywork)and tried to start it it wouldnt go. It would crank, but no start. Then a few days later I tried, and it started up. Then after I shut it off, and tried to start it again, it wouldnt start.
Also, when It was still getting the bodywork done on it, before I brought it home, I started it and drove it up and down the street once. It died going down the street so I had to push it back. I tried to start it, but it just kept cranking.
What is going on!?!?!?
And Ive tried the fuel pump, I took it out and gave it some juice and it ran fine. Ive tried fuse 11 & the other fuel fuses, and Ive tried the relays(all 3).
