Hey guys, I found a 325i yesterday for $600 that I'm interested in purchasing. The only problem that I know of with the car is a broken rocker arm on cylinder 5 (It might be on cylinder 6, I can't remember.) The owner told me it was the result of a broken timing belt. When the belt broke, she pulled of the road because she knew what had happened from a previous experience with another car. The timing belt has already been replaced.
So, I'm wondering:
1. What damage could the engine have sustained from the timing belt/rocker arm? Maybe a bent valve, push rod?
2. How difficult is it to replace the rocker arm? I've searched, but with little luck. I've been getting mixed answers, some say that the head has to be removed to replace the arm while others say that you can just remove the rocker shaft. (Are there any guides on how to replace a rocker arm?)
3. Would it be okay to just replace the broken rocker arm and leave the others alone, or should I replace all 12 at the same time? Are there any other parts I should replace at the same time?
Thanks in advance!
P.S. I'm new to E30s and car maintenance in general, so go easy on me! (However, my grandfather is very knowledgeable with cars and he has a lift and most of the tools I would need.)
So, I'm wondering:
Thanks in advance!
