Car won't start this morning!!!!
  • Coujer
    • 51
    :hitler: Its been running great till this morning, I went to start it and got nothing just a couple of clicks and thats it, everything lights up fine. Checked all connections, everything seemed fine. The battery does look old and looks somewhat corroded... I'm going to try and jump start it later when I get back home but any of you guys got any ideas?
  • 5spoke
    • Sep 2007
    • 1729
    It's broke.
    • White325is
      • Oct 2006
      • 5947
      Originally posted by 5spoke
      It's broke.
      You think? I dont think its broke.
      • Need4Speed1299
        • Oct 2007
        • 119
        Check alternator by jumping it and disconnecting the battery. If it runs, alternator is good and the battery is bad.
        • That Nice Guy Beck!
          • 143
          def batt
            • 143
            milwaukee? im here now, interesting town to say the least
            • Coujer
              • 51
              Okay well it jump started no problem and drove great, so I went to Kragen and got a new battery :hitler: 100 bucks!!!! I was like holy crap. So it was fine last night... Got in it this morning and nothing, I'm thinking alternator!! It jump started with no problems this morning...
              • Eecen
                • Jun 2010
                • 1235
                Battery light on while driving? ..or is that bulb burn out
                Check the alternators carbon brushes/voltage regulator before you go drop $200 on a new one
                • Coujer
                  • 51
                  I think the bulb is out, I haven't seen it lit...
                  • JBird
                    • 980
                    Why did you buy a new battery before trying to figure out what the problem was? You should have checked the alternator first. Your old battery was probably fine, what a waste of $100 bucks.
                    "The Camry is an appliance, not a car. It attracts folks who have the same regard for driving that they have for washing dishes,
                    i.e. it's a necessary but somewhat unpleasant chore and they want something to make the task a little easier and insulate them from the process."
                     - my friend, Número Veintiséis
                    • Coujer
                      • 51
                      Well I had them test the battery first and it was shot.
                      • Vince30
                        • 2318
                        Will e30s run without the battery hooked up? Some cars won't even if the alternators good. Just hold a volt meter on the battery and have someone start the car, the battery should drop to about 9-10 volts under cranking then come back up to around 13, if it does not come back up its your alternator. If it drops below 8.8v you bought a bad battery.
                        If it looks old and he does not know the last time one was put in, it wasn't a waste of money at all, they only last about 4 years.
                        • JBird
                          • 980
                          Yep, you're right. But I don't think he said anything about how old the battery was. :) The alternator is probably super old too.
                          • Coujer
                            • 51
                            The old batter was all corroded and looked to be leaking, so trust me that battery had to go anyway.
                            • Vince30
                              • 2318
                              What are you still doing on here? Check that alternator son!
