Does this sound right? (m42 throttle body, question)
  • call me jack
    • Jul 2010
    • 425
    I was talking to a guy at school, the other day and he told me that he wanted to run MS on his 318is, but to do that he would need to retro fit in a different throttle body/tps. His logic was that the m42 tps was non varying, and only read "idle" "on" and "wot" inputs (which just seems crude).
    Can any body shed some light on this? I searched around a little bit, but couldn't find much. I even looked in my bently for a wiring diagram, at which point i discovered it doesn't feature the m42...
  • DaveSmed
    • Apr 2007
    • 1407
    The M42 is a true three wire potentiometer variable output sensor. He's thinking M20.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • gearheadE30
      • Jun 2007
      • 3734
      basically what that means is that there is no need to retrofit a different sensor. potentiometer=variable resistance depending on the rotation of the throttle. The m20, along with other old engines, use the on-off switch. Apparently people typically retrofit M50 tps's to the M20 to run MS, but the m42 doesn't need that.
      Project M42 Turbo
      • call me jack
        • Jul 2010
        • 425
        i see. i should've looked at that in my bently, if it applies to the m20. thanks guys.
        • tjts1
          • May 2007
          • 1851
          Yes its a POT. Now with diagram.
