Does anyone make an alternative to the stock instrument cluster you can get for late model e30s? Nothing on mine works but the speedometer, and paying 150 for one on ebay used seems kind of silly.
instrument cluster alternative
I'd love to see a custom LED cluster that looked something like this
but after I saved it I realized it wasn't really what I thought it was, looks like just a modified stock cluster.
but I am in for ideas on this as well
also there are used German clusters for sale on here for cheaper than $150 btw( f ; _ ; )f
$150 for a fully working cluster is not expensive, considering how much they cost new... price one out. OR send yours in to get it rebuild
STACK makes an alternative, figure about $1000 and you'll be FUH RAZE.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
www.realoem.com add it all up. You'll understand that $60 for new gears is a small change to have a working odo.... or just deal with it and drive it like a beater.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
guys, its most likely youre SI board, not the gauge itself.....Last edited by Ramgoat; 10-13-2010, 09:03 AM.
Hope you don't work at a dealer as service advisor lol.
Could be lots of different issues. SI board only does so many functions... for example if the odometer is physically broken or temp/fuel gauges have connections problems, or an issue with wiring , or ground, or sender issues. it wouldn't be an SI board issue would it?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by Jean View PostHope you don't work at a dealer as service advisor lol.
its edited it for your clarity
in any sense, Ive got tons gauge clusters for sale, check my sig if it is a mechanical problem...Last edited by Ramgoat; 10-13-2010, 09:11 AM.
Oh, did you want to be big baller? ;)
Just get the gear fixed if it's not working and you really need it.'84 318i M10B18 147- Safari Beige
If you buy a working e30 cluster with some exceptions, it will work. M3 clusters are different than all others. M42 clusters have a different fuel gauge. 325i clusters have a different redline than 325e supereta clusters which have a different redline than normal 325e clusters. To the best of my knowledge they all also have different code plugs, but those can be swapped between clusters. Just try to get the right one for your model.
