Valves tick louder after tune up...WTF
    After buying this car like a month or so ago today i decided to do a tune up so i put new Wix air and Fuel filters,Ngk spark plugs and wire set new Berk and Ankley cap and rotor(the reason i put brand is in case there is an issue with any of them).On top of that i reset the ecu removing ground cable
    So i fire up the car let it sit for a minute or so it idles way better than before, no wonder plug wires were stripped on the coil cable and the pick up cable.But after i came from a 1 miles test around block i notices valves tick is way louder now.If i would change oil i could understand but i did not change oil.Car is not misfiring still idles great pulls hard not noticeable power loss.
    Any ideas could this be just a coincidence?
    is the ticking continuous or only when under load?
    fb: @WerkstattEuropa
      Are you sure it is the valves? It could be a fuel injector (or injectors) as well.
      If you don't know the last time it was done you should look into doing a valve adjustment soon as well.
      1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
