Alpina Vent Gauge incoming-need some help!!
  • stormspike
    • 401
    I've finally sourced my white unicorn of the E30 parts. The problem is that their is no wiring harness-only the gauge and controller with connector. Is there anyone out there that can make a connector? Any idea on part numbers of the sensors needed? Does this use regular VDO sensors? Info on this unit is not too easy to come across. I've found the following diagram.
    I've translated the following:
    Pin 12: Oil Temp Sensor
    Pin 11: Final drive oil temp sensor
    Pin 10: Oil Pressure Sensor
    Pin 1 and 4, Power
    Pin 5: Ignition Plus ?
    Pin 15: Lighting
    The circle is the manifold pressure tube
    Can I use existing sensors (Oil Temp)? What sensor is needed for final drive oil temp? Is there a spot for that sensor or does it need to be tapped? Does the manifold pressure tube just run to the manifold or is there a sensor? Unit powers up with just the power activated so it works, but no harness or sensors.
    Ill pay for anyone able to help with the plug creation. Wiring is not my specialty and with this stuff NLA, dont want to ofry controller :)
    Here is a pic of the unit:
    Thanks for the help with this project!!
  • Car Addict
    • Mar 2007
    • 1100
    can't help sorry but uber jealous
    • charlescho
      • 515
      wanna sell it :rofl:?
      • Anguz
        • Jun 2010
        • 1394
        woa ive never seen something like this before
        good luck and post pics when youre finished
        • AndrewBird
          The Mad Scientist
          • 11892
          Numbers 1,4,13 and 14 are not power, they are ground. And #5 is power coming from the ignition to turn it on (switched power).
          No idea what to do about a connector though.
          • dreamchasin
            • 3890
            i must say this is probably one of the most rare e30 items.
            90 325is alpine2 m50b25 becoming a dorifto car.
            • bmw325csi
              • May 2007
              • 4045
              thats ghetto, you dont need it, sell it to me!
              harry/harout
              • structured
                • 954
                Try sending StereoInstaller1 a PM. He is quite good with electronics (stereo systems mostly). I know that he has been helpful to myself and many others. Otherwise, good luck.
                • Eric
                  • 5138
                  Contact John the owner of S14power.com. he made a repo of this and can probably help you with a wire harness. He is not cheap...
                  • stormspike
                    • 401
                    Thanks! I'll shoot off a few pm tonight.
                    • stormspike
                      • 401
                      contact
                      Eric,
                      Do you have the John's contact over there? Forums are closed for registration.
                      thanks!
                      • stormspike
                        • 401
                        Power
                        Thanks for clearing up the power. That would be very bad to cross the ground and live power :)
                        • stormspike
                          • 401
                          Anyone have any ideas on the part numbers of the needed sender units?
                          • sharky
                            • Jan 2005
                            • 2672
                            first of all I hate you right now, second, please send this to george graves to have him duplicate it somehow and third sorry no help.
                            • StereoInstaller1
                              GAS
                              • 22679
                              I am gonna bet the stock E30M3 (S14) sensor is fine for oil temp...hell, I bet most any VDO sending unit ever made is alright for oil pressure or temperature. It only makes sense for a manufacturer to remain consistent with their sensor values.
                              hinterachsgetriebe means "differential" so I am assuming that would be diffy temp. Do you know if this holy grail of instrumentation has diffy temp? I can't recall ever seeing the diffy on an E30 (M3 or not) have enough harness, I assume it would have to be added.
                              The thing has no need for memory power, thus switched ignition (I would use IGN2 myself, no sense having this on while cranking), illumination and ground are all that is needed.
                              If you tied that to power windows, you are golden.
                              Are VDO sensors hard to find? All I am seeing is oil temp and oil pressure and diffy temp, and of course the manifold pressure...but it has a MAP in it obviously.
                              I would not hesitate to wire that thing in.
                              Luke
                              Closing SOON!
                              Thanks for 10 years of fun!
