Just curious as to what you guys are using to refill the diff and tranny. It's kind of an emergency and I remember the last time I changed the tranny fluid, I used a cheap hand pump found at a local auto store and it sucked. It was a weak handpump with a hose on one side to such the fluid from the bottle (redline) and hose on the other end pumping into the fill hole. Leaks, weak suction, etc.. created a mess. I want to avoid that when I change out the diff fluid tonight.
So what do you guys use, and where can you buy it? I'm sure there's a ton you can order online, but is there something at a local hardware store (home depot, orchards, ACE) that will work? Ideally it'd be nice to have a big syringe with a tube. Thanks
[IMG]http://www.r3vlimited.com/board/
