Brake Fluid on clutch!
  • BMWerke
    • 893
    i am still stuck doing my tranny swap, we were tryin to bleed my slave cylinder and it waz drawing fluid out of the brake fluid reservoir but it was not gettin stiff. come to find out the slave cylinder was squirting fluid in the bell housing. will this fuck up my new clutch and machined flywheel????
    '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
    '86 325e- Donor car for swap/parts car
    '00 323i- BBS 197s Totalted
    '89 740 turbo Volvo- Donated
  • Danny
    • 14216
    Idk, it'll probably just burn off.
    • KillaCams
      • Mar 2008
      • 998
      I also would think it would just burn off, maybe avoid launching the car hard before you're sure it's burned off to avoid glazing the flywheel
      • DREWHALL
        • Feb 2006
        • 1207
        Any kind of fluid getting on the friction disc would concern me, as the glazing usually happens there. It may burn off though...it just getting on the flywheel isn't going to hurt it unless the clutch keeps slipping really bad. Just try cleaning it out and see what happens. If you're paranoid about it just try to find the friction disc by itself.
