Diff advise needed.
  • gsxrcop
    • Apr 2008
    • 161
    Diff advise needed.
    Thought I would try here since I got no response in the drivetrain section.
    I have a 91 318 with a 4.10lsd small case diff. I was told all I need to do with a 325 diff is swap my flanges and rear cover for it to work on my car.
    I bought a 2.93lsd and found the flanges seem to fit fine but the rear cover is different. Can someone shed some light on what I need to do to make it work. Can I get a e30 325 rear cover? I take it the 2.93 is a med. case correct? Thanks for any help.
  • gsxrcop
    • Apr 2008
    • 161
    No help?
    • Gooch
      • Dec 2006
      • 1674
      You need a medium case e30 cover.
      '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
      '87 535i - Vacuum brake conversion [SOLD]
      '93 525iT - 5-speed swap - 320k and counting
      '09 328xi - 6-speed
      • Supadave
        • 1006
        Why do want to put a 2.93? the m42 would be alot happier with the 4.10. Are turbo'd?
        https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
        • gsxrcop
          • Apr 2008
          • 161
          Yes it's boosted. I would like to lower the revs on the freeway.
          • Supadave
            • 1006
            What car is the 2.93 off of? How many bolts are on the diff cover?
            • gsxrcop
              • Apr 2008
              • 161
              I think he said it came out of a 325e, without it in front of me, I do remember there being 2 bolts on top and the small case only having one, this being at the top center of the cover. I think there are a total of 8 bolts? That sound right?
              • Supadave
                • 1006
                ya that sounds right. I dont see why you would have to change the case. The only thing i can see being a problem, is the length of the drive shaft. You can cheat a lil on this, it should no more then 20mm 25mm differnce. Here check this out maybe this can help with choosing a rotio, I still think 2.93 is to high http://r3vlimited.com/board/showthread.php?t=112421
                • call me jack
                  • Jul 2010
                  • 425
                  on the note of rear diff. does any body know where to find rebuild kits for them?
                  • F34R
                    sLaughter
                    • 12376
                    Here is a thread on my 2.93LSD rebuild.
                    Everything is covered on where to buy and what is needed.
                    Instagram: @BWeissLeather
                    Current cars:
                    ~ '87 325 M30B35 swap
                    ~ '87 535
                    ~ 01 540 Msport 6spd
                    ~ '06 X5 4.8is
                    • gsxrcop
                      • Apr 2008
                      • 161
                      I just want to know if I can get an 325 med case rear cover and use my flanges. Sorry if you thought I was saying I may need to swap cases.
                      With my current ratio of 4.10 and my 16" wheels, gps mph shows 3200 at 60. I need that lower, there is no 1st and second gear under boost anyways.
                      • Gesucht
                        • Nov 2009
                        • 100
                        Have you tried a wrecking yard in your area? The one that requires you to bring your own tools usually has a good deal.
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          Did the 2.93 not come with a cover? Swapping from small to medium case is something of a non-issue...the flanges are the same and the rear cover, as long as the diff was in an e30, is also the same, I'm fairly certain...
                          Project M42 Turbo
                          • gsxrcop
                            • Apr 2008
                            • 161
                            The diff I bought came with a cover but it was different than an e30, it has a mounting bracket that comes straight out from the top. I think when he said it came out of a 325e, he meant his car as he switched to a 3.73. I believe this diff was from a e28? Like I said the flanges seem the same, but the cover is totally different. I'm in search of an e30 med case cover in the Seattle area, any leads?
                            • Gesucht
                              • Nov 2009
                              • 100
                              There's one posted on CL
                              - differential (<3:00:1 open)
                              "Give me a call if you want to come take a look at something, or send me an email with a parts list of what you need. I can be reached at 2O6.383.4736"
                              Maybe you can get that for a good deal.
