I know it's stupid, but just looking at my options..
1991 bmw 318is
-Sterling silver
-5 speed
-Tan interior
-ABS
Good:
-M50 swap
-Getrag 260 with lightened flywheel
-E28 535i motor mounts
-UUC stainless steel brake lines
-E21 trans mounts
-EricT trans brace
-BavAuto perfromance ignition coils
-E30 ix brake booster and master cylinder
-E36 318ti steering rack
-E36 ti radiator with a generic parts store electric fan
-Tokico hp blue shocks with ground control coils (450 and 700lb springs)
-Pro sport water gauge
-New tstat and housing
-One silicone radiator hose one rubber lol
-New front rotors with hawk hps pad that have been used for 2 autox-s
-New rear shock mounts
-New control arms, m3 offset bushings, tie rod ends, tie rod boots, adjustable sway bar links
-IE 22mm front sway bar
-New oil filter housing gasket
-US elipsoids with generic hid's
-TRM performance chip ( not installed yet)
-413 ecu
-Magnaflow 14832 muffler with new Magnaflow universal cat and 2 1/4 pipes
- Ebay SS headers
- New knock sensors, t/b gasket and intake manifold gaskets
-Redline mt90 trans fluid, mobil1 75-90 diff fluid
-New strut mounts
-New intake boot
-New exhaust manifold gaskets
-New e34 throttle cable
-NEw pressure plate bolts
-New center support bearing
-New oil pan gasket
-New 2002 remote brake fluid reservoir
-New pilot bearing
Bad:
-needs paint
-no a/c
-few vibrations (working on fixing these)
-needs door seals
-few cracks in the seats
-door locks need to be rebuilt ( working on fixing these too)
Other than that it's in great shape. But the first few times i drove it i realized i belong in an e36 and this kinda isn't for me. But if i can't get much out of it, i may just keep it. It's setup for autox but can be dd too since all the interior and sound deadening is still in.
It would probably come with basketweaves on azeni's.
I'm sure i'm forgettings ome stuff, but that's most of it.
Few pics:
I would most likely try and trade it for a e36 coupe. Maybe an m3 :D
1991 bmw 318is
-Sterling silver
-5 speed
-Tan interior
-ABS
Good:
-M50 swap
-E21 trans mounts
-EricT trans brace
-413 ecu
- Ebay SS headers
-New strut mounts
-New intake boot
-New oil pan gasket
-New pilot bearing
Bad:
-needs paint
-no a/c
-needs door seals
Few pics:
