AWFUL shake when I hit 40mph
  • Dtmnuka
    • 124
    I drove all day and right as Im getting home i take off from a stop light and I climb up to 40mph and my car starts a weird vibrate feels like its coming from the back of the car. The seats shake and it almost feels as if something is rubbing against something else and shaking the whole car. Feels real nice on my back but what the heck is it?!
    Its not doing anything else funny.
    HELP GUYS!
    thanks.
  • 87e30
    • Jul 2008
    • 5676
    More info.
    Does it happen under acceleration?
    Could be driveshaft, guibo, center support bearing?
    Does it just happen when crusing?
    Could be wheels are balanced, ball joint going bad, ...
    I just hate everyone.
    No need for discretion.
    • Dtmnuka
      • 124
      the car is FINE until i get at 36-and up. then after Ive reached that speed itll do it harder and harder the faster I go.
      Is that a cheap fix? by cheap I mean Im a college student working barely any hours a week haha
      • txtorquemade
        • 1758
        You work for barley?
        I can barely comprehend that.
        sigpic 1987 325is
        • Dtmnuka
          • 124
          smart ass
          • Edev
            • 3731
            You'll need to get under the car and check out everything that 87e30 said.
            M Coupe
            • 87e30
              • Jul 2008
              • 5676
              So does it do it while accelerating? Or just cruising?
              Sounds like just doing it more noticeably while cruising at higher speeds. I'd suspect unbalanced tires, bad ball joints. Probably will want to inspect both front control arms.
              Maybe it's rear bushings though, I don't have experience with which ones will specifically cause shaking. I'd guess rear trailing arm bushings or subframe bushings could do it, though.
              • Joe G
                • 2942
                did this just start all of the sudden?
                Current Car: 2011 BMW 135i, M-Sport, 6 speed
                Originally posted by lambo
                Sounds like you need a massage.
                Originally posted by kpeng
                Who the hell is Vlad?
                • OOMPH!
                  • 3487
                  It could be something as simple as a piece of tread on your tire fell off, this happened to me and had the same symptons. Give your tires a quick check.
                  • Dtmnuka
                    • 124
                    Ill check my tires tomorrow. Ya it just randomly started right around the corner from home. Ya it doesnt do it until that speed. just cruising after 35+
                    • BrownBeanE30
                      • 965
                      i had the same problem turned out to be the center support it died on me and it was a pain in the ass to fix kind of :)
                      Originally posted by InuFaye
                      silver is old man color car. you need dat BRO-SECA BLUE.
                      so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
                      An S5x is like the girl you want to marry - an m30 is the girl you don't bring home to mom.
                      • 87e30
                        • Jul 2008
                        • 5676
                        This should just happen under load, ie when accelerating. Or at least it will get worse when accelerating as far as I know.
                        • Acidblast
                          • Apr 2005
                          • 63
                          check your Guibo and your Center support bearing. i'm in the process of changing both of mine right now. Getting mad vibration in 2nd and 3rd gear around 50km/h.
                          • Massive Lee
                            • Sep 2006
                            • 6782
                            Vibrations at low speed are usually related to driveshaft.
                            - Check guibo at the tranny and center bearing.
                            - Verify that the U-joints on the driveshaft are not seized or loose.
                            - But also check the obvious: da wheels.
                            massivebrakes.com
                            • pawi30
                              • May 2007
                              • 1091
                              Does it stop if you reach a higher speed? 50, 60? or does it just continue to get worse. I would guess bent wheel.
                              Originally Said by Bob Marley
                              "BMW make pure trouble!"
