signs of a bad motor?
  • mr.vang
    • 4371
    i crack my m42 oil pan whiling driving on the freeway. i have a bad feeling after i hit the pot hole so i stop asap. when i parked, close to 1Qt of oil leaked on the stop. so, is there anything i should look for to see if the motor is still good? or anything sign of a bad motor?
  • LivingLegend06
    • Dec 2006
    • 1604
    If you only lost 1qt and you stopped the car quickly the chance of anything being damaged is slim.
    I would just fix the pan and keep driving it.
    • Holland
      • Nov 2008
      • 7212
      It actually takes quite a while for a motor running on no oil to grenade. You should be fine.
      Originally posted by DEV0 E30
      • ttrousdell
        • Nov 2009
        • 1770
        same. ive seen dumb drivers drive on 3 qts for a while. long as you dont hear any bad noises
        The Build:
        • selturk
          • Dec 2008
          • 1197
          don't worry m42 will survive..
          • Eecen
            • Jun 2010
            • 1235
            So you hit the pot hole, stopped a bit after, and only 1 quart drained out after you stopped?
            How long were you driving for after the pan cracked?
            • mr.vang
              • 4371
              no that was the last 1QT that came out lol. the engine bay was smoking already but i think that was due to the exhaust pipe burning the oil. when i look under the car, everything after the motor was soak with oil, even the diff and my back bumper to my tail light.
              • mr.vang
                • 4371
                i drove close to 1-2 mins after i hit the pot hole. no, the last 1QT leaked out when i park.
                • ///digitalme
                  • Dec 2009
                  • 2088
                  if youre concerned...pulled the valve cover...it should tell you a lot
                    • 37832
                    If oil still was leaking out, it still had oil! You'll be fine.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • HarryPotter
                      • Jan 2010
                      • 3642
                      just run it hard to get all oil hot then it will divide into more oil cause heat makes things expand. or was that cold. fuck.
                      John F. Kennedy
                      • Eecen
                        • Jun 2010
                        • 1235
                        Yeah, I wouldn't be worried about it.
                        And I doubt you were riding it very hard after the nice thud that comes along w/ a cracked pan.
                        Been drinking tonight?
                        • HarryPotter
                          • Jan 2010
                          • 3642
                          nah man just spreadin my knowledge. its a monday for fuck sakes.
                          John F. Kennedy
                          • mr.vang
                            • 4371
                            thanks for all the input guys/gal. anybody have a m42 pan laying around?
                            • bcausey
                              • Jan 2010
                              • 316
                              Shouldn't have to worry about rust for awhile, although waxoyl is probably a better option...lol -
                              Damn potholes...
