dif swap need some help in a hurry!
  • gokepsgo
    • Jun 2010
    • 202
    Hey guys, yesterday I decided to finally replace the dif out of my eta to a 3.25lsd. So far I've unbolted the drive shaft and the axles "flanges?". Anywho I'm having a ton of trouble getting the mounting bolts off due to clearance issues and a lack of lube. And on top of that I have no idea how I'm gonna squeeze a socket and torque wrench on to the bolts on top when I put it back together. Is there anything I should be doing that will make this easier? Any help or tips would be greatly appreciated.
  • ///Mayhew
    • May 2007
    • 285
    a wrench works on top, and crows foot wrenches for the torque wrench
    1989 325i MT2/4dr
    My life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather i will skid in broadside,thoroughly used up,totally worn out and loudly proclaiming....WOW..What a ride!
    • e30trooper
      • 11576
      take tires off, use breaker bar to loosen the 4 tops bolts up. un do half shaft (axles)
      this is a pretty easy job, GL
      • blueapplesoda
        • Dec 2005
        • 1904
        use two box wrenches to get leverage on the bolts up top, curved box wrenches would work too. Then use a bottle jack and jack up slightly to relieve the topside of the diff so bolts can come out easier.
        • gokepsgo
          • Jun 2010
          • 202
          Thanks guys. So what you're saying is pretty much get creative. I was hoping this would be a lot less of a pita before I started into this mess hah. It also sucks when you start and find out you don't own a single 17mm wrench and all the auto shops are out of commission because some ass had to knock out a telephone pole. The easy bolts should be no problem. Is there another way to get the top bolts off and torqued back without this "crows foot"?
          Don't have a lot of money and I'm sure they're not cheap.=(
          • Julien
            • 7471
            don't worry about torque spec, just get it nice and tight with a 17mm wrench. I recommend a 17mm speedwrench to make the job 1000x easier. you can also remove the rear diff bolt and give yourself more room to work with.
            Julien
            Build Threads:
            • Dude
              • 1119
              You gotta get creative, its a simple job but its not that easy. I ended up cutting a 17mm open end wrench in half so i could get a breaker bar on it. Ratchet would be a good investment for this, ill def have them if I ever have to do it again.
