So i just replaced my coolant hoses for the radiator on '87 325e (w/'87 325i auto radiator, in it). i replaced them because i was leaking coolant from each end tank port. so i put every thing together, fill my radiator and expansion tank, and took it out for a test drive.
I didn't get too far when my coolant light came on (about 4 miles i was driving in a loop around my house), so i took it back home to investigate.
It i tightened everything thing up but it appears that you can see moisture coming from where the end tank meets the aluminum. (it could be ATF though, seeing as it's right next to once of the tranny cooler ports)
so my question, is it possible that my radiator just started leaking just because? Or should i see if i can get my hoses a little tighter?
