Originally posted by mr.vang
View Post
power washers. Gas or electric?
Originally posted by FusionIf a car is the epitome of freedom, than an electric car is house arrest with your wife titty fucking your next door neighbor.
William Pitt-
steam--is the best
I have an idea to take a 15-30 gallon up right compressor tank, fill it half way with water, set the turkey deep fryer burner set up and heat that to 50?? psi steam. Feed through 1/2 insulated pressure line to 120 air compressed sprayer head.
This is just theory on the afore mentioned contraption.
join the E30 Cabrio owners gruppe
click here for details
Originally posted by mrsleeve View Postyeah they do make the very best power equipment out there other than chainsaws and similar.
Basically, don't ONLY look at Honda. A Briggs, Kawasaki or Subaru-powered gas unit will do just fine, too and will probably save you a few $$. Just DON'T get a Chinese-built unit. Absolute garbage.
Originally posted by quickervicar View PostBasically, don't ONLY look at Honda. A Briggs, Kawasaki or Subaru-powered gas unit will do just fine, too and will probably save you a few $$. Just DON'T get a Chinese-built unit. Absolute garbage.
Ich gehöre nicht zur Baader-Meinhof Gruppe
Originally posted by Top GearJust imagine waking up and remembering you're Mexican.
Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
Originally posted by u3b3rg33k View PostAll of those engines have real oiling systems (not the splash paddle system), so that probably has something to do with it.
depending on what you want it for. I have a 11hp honda belt driven pressure washer for my business it's a $2000.00 machine. I use it everyday in the summertime for 5-10 hours. It's a lot nicer machine than all the junk direct drive ones you see in home depot. I have small electrics also but for anything heavy duty you need a gas engine. Just no matter what you get make sure to use the right angle tip for the application. And if your gonna spend money go honda belt driven with a cat pump.My Multi car part out. Need a part? Pm me...
http://www.r3vlimited.com/board/showthread.php?t=193051
Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
http://www.r3vlimited.com/board/showthread.php?t=215044
Have you done business with me? If so leave me feedback here...
http://www.r3vlimited.com/board/showthread.php?t=188307
