getting out the sound deadener
  • 91Saleen#15
    • Mar 2006
    • 230
    I waited for a cold night.
    Richard
  • lolcantturn
    • 4588
    haha brilliant. I need to take mine out as well. How much does that stuff weigh anyway?
    Originally posted by TSI
    OEM+
    • MattM
      • Apr 2009
      • 931
      ahaha, i must have been lucky, i just grabbed mine and pulled it out, it came out in one big sheet... no fight no mess
      Full Build Thread Here
      • StereoInstaller1
        GAS
        • 22679
        I bet I have pulled that crap out of 25 cars by now...my boxes don't fit with it in.
        First: guys, this is NOT sound deadner. It is a ballast, intended to help achieve the legendary BMW front/rear weight balance. You may have noticed it really doesn't do shit as far as sound reduction, right? I mean yeah, it does a little, but hardly nothing.
        Have you ever seen BMW do anything that ineffective? It weighs about 57 pounds.
        I have done them using dry ice, heat guns, air hammers hammer and chisel...you name it I have tried it. I think this guys idea of frozen + air hammer is the winner, unless you get very lucky and have it simply pull up, which has happened only once for me.
        Closing SOON!
        Thanks for 10 years of fun!
        • browntown
          • Jun 2004
          • 3524
          dry ice is the shiznit,
          break it up, spread it out, cover in towel, wait twenty minutes, smack it with a mallet
          heat gun leaves a gooey mess, and I burn't my hand doing it that way.
          • Raxe
            • 5346
            Why would I want to remove the weight directly over the back wheels? :s
            • charlescho
              • 515
              to put a lukebox in :giggle:
              • lolcantturn
                • 4588
                So you can remove the same amount of weight over the front wheels :giggle:
                OEM+
                • Jparkr
                  HR Admin
                  • Jan 2006
                  • 3494
                  Thats a great way to do it if you dont give a shit about the paint.
                  I take 3 flood lamps and a meat thermometer put it all in the trunk. Wait till the ambient temp is about 220f put on gloves, peel that shit right out of there.
                  takes about 20 minutes, 5 or less of it is actual work.
                  1987 PRO-3 car /1990 325is (2.7i Concours)
                  • browntown
                    • Jun 2004
                    • 3524
                    ^^ depends on the car, every car I can think of off hand was primer under the trunk tar because they sprayed the body color over the tar. If memory serves bronzit tar was the most difficult.
                    • lolcantturn
                      • 4588
                      Well then I'm not looking forward to removing my tar :-?
                      Should I leave the trunk ajar over a real cold night (About 15*F) and just manual hammer and chisel it?
                      OEM+
                      • browntown
                        • Jun 2004
                        • 3524
                        no - use dry ice. I tried the above and put a cold chisel right through the floor of my trunk. No sharp objects next to thin steel.
                        • StereoInstaller1
                          GAS
                          • 22679
                          I would smack it firmly with a hammer if it is 15 degrees out. I bet it shatters into big chunks and falls out nicely.
                          Closing SOON!
                          • davem
                            • Jun 2010
                            • 705
                            Most of mine came out quite easily, the adhesive was starting to stop working. I used a screwdriver & rubber mallet to get the rest out.
                            • JJe30
                              • 2044
                              Mine came out in one piece. Just grabbed it and it all pulled out.
