What a day...what to do...
  • kingston
    • Jun 2010
    • 2669
    #46
    Ah, a trip down memory lane from when I had first gotten my car...
    Originally posted by Emre
    Here's the not-so-secret formula for turning the E30 into a go-kart:
    Strip out all the non-essentials. Pick up a set of lightweight 15x7" or 15x8" alloys and put some high-quality 225/50-R15 or 225/45-R15 rubber on them. Put on a track-biased suspension, such as the excellent Ground Control kit or just some TMS J-Stock springs and custom-valved Bilstein dampers. Put on some camber plates. Replace the worn out rubber subframe, control arm, trailing arm, and rear shock mount bushings with urethane. Get a proper 4-wheel alignment. Stick on Lee's "Street" front big-brake kit and the E32 750iL master cylinder upgrade. Put on a shorter Z3 steering rack and the steering wheel of your choice (I like the Momo Model 78 myself). Upgrade the seats to some Recaro SRDs.
    It's funny, but over the years I ended up doing almost ALL of these things.
    15x8 TRM C1s with sticky tires
    Ground Control coilovers & camber/caster plates
    Poly Subframe bushings and RTABs
    Good alignment, running -3 degrees camber in the front, zero toe
    Lee's/Massive's 'Sport' BBK
    25mm brake MC
    E36 steering rack (non-M)
    MOMO Mario Andretti steering wheel
    Recaro Pole Positions
    Emre, apparently you know your stuff!!!! <3 my car!
    Originally posted by LJ851
    kingston is the play by play announcer for this thread.
    ‘Tis by the grace of God that my cars run!
    Originally posted by unloadedak
    #teamross
    Siobhan's Build Thread - UPDATED!
    • noid
      • 1537
      #47
      Should of went m60.
      Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
      Your resource to tools and tips: www.rtstools.com
      • kingston
        • Jun 2010
        • 2669
        #48
        Eh, I am actually really happy that I went S52! That car rocks on track with the current setup :D
        #teamross
