Hiccupy acceleration
  • Evan12
    • Dec 2010
    • 346
    On my 87' 325is when I accelerate flat out I usually get a hiccup or two on the upper end of the tach ( 4-5 k rpm). Is this normal for e30s? If not any ideas?
  • dsobering47
    • Oct 2007
    • 697
    No, its not normal. Its probably not normal for any car, just as a pro-tip. What sort of hiccup? Like a just-chugged-two-beers hiccup? Or like you just-had-Thanksgiving-dinner-and-you-immediately-regret-that-second-helping-of-pumpkin-pie hiccup?
    • 87e30
      • Jul 2008
      • 5676
      The pro-tip above is spot on. haha.
      fuel or ignition would be my guess.
      I just hate everyone.
      No need for discretion.
      • dsobering47
        • Oct 2007
        • 697
        I would e-guess a misfire of sorts relating to ignition. But thats a definite e-guess.
        • HarryPotter
          • Jan 2010
          • 3642
          Does this tend to happen after coming out of a corner?
          John F. Kennedy
          • Evan12
            • Dec 2010
            • 346
            No, just flat out anywhere, it's like a quick blip, almost a loss of power for a second then it comes back. When I say quick it's pretty quick. I will be accelerating hard then get to about 4.5k and it hiccups then comes back at about 100 rpm higher or 200 higher then just continues with my acceleration. If I hold my tach while driving at 4 or 5k though it is fine, no bumps or anything.
            • Evan12
              • Dec 2010
              • 346
              Bump. Threads r movin fast.
              • gearheadE30
                • Jun 2007
                • 3734
                How old is your distributor?
                Project M42 Turbo
                • Evan12
                  • Dec 2010
                  • 346
                  I don't know if the previous owner replaced it so I am goin to assume as old as the car. :/ are they expensive to replace? I plan on cleaning injectors, checking sparks and fuel pump so far as well with replacing ignition wires. I don't know much about the distributor. Is it easy to DIY or would you recommend a mechanic?
                  • freeride53
                    • 11972
                    Fuel Pump. Was just like that before mine went out. Quick Fix. ;)
                    edit: or fuel filter, both happened to me.
                    1983 Peugeot 505 STI
                    1992 Volvo 240 Wagon
                    • Evan12
                      • Dec 2010
                      • 346
                      Sweet. Thanks. I will try those things.
                      • HarryPotter
                        • Jan 2010
                        • 3642
                        fuel filter, fuel pump, distributor cap and rotor, plugs, wires, coil, anything really.
                        Mine use to do it occasionally after a hard corner with low fuel in the tank.
                        John F. Kennedy
