Hi everyone,
I am new to the E30 scene...just picked up a 1988 325iC. Known issue was that the rear half shafts are bad, and the subframe mount bushings suspect.
I just jacked up the rear to look, and the two sides aren't symmetrical. Based on the pictures, which one is correctly installed? If I look up under the one where the frame is nearly together, I can see the bushing, and it appears to be the same as the other one. I figure if I have to replace one, I should do both at the same time I am putting in the half shafts and new shocks. Thanks for the help! It has a vibration/rumble from the rear under hard acceleration or above 55 mph which is directly related to the above issues.
The bonus is that I found out it has an LSD! VERY little slop in it and clean oil!
Tim
Tim
