2wd vs awd in snow
  • Bimmerman325i
    • 6854
    #61
    The better braking would be due to more mass over the front axle/front half of the car. More driven wheels with equal tires and brakes does NOT change braking performance, but added/redistributed mass does.
    2017 Chevrolet SS, 6MT
    95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
    98 M3/4/5 (stock)
    • u3b3rg33k
      • Jan 2010
      • 2452
      #62
      I'm not quite sure how that works, unless the AWD system increases rear bias and that happens to be advantageous. The iX is a heavier car, and given the same tires on the same road, I would expect the lower mass car to stop faster, all other conditions equal.
      Ich gehöre nicht zur Baader-Meinhof Gruppe
      Originally posted by Top Gear
      Just imagine waking up and remembering you're Mexican.
      Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
      • Bimmerman325i
        • 6854
        #63
        ^ the added mass on the front wheels gives better front end braking, but not all that much. Overall though, yes, the heavier car will stop slower than a lighter car.
        98 M3/4/5 (stock)
        • Gladeoffer
          • Mar 2008
          • 48
          #64
          From what I understand the VC and ABS system in the ECU have something to do with it all. Just my 2 cents.
          • Vtec?lol
            • Dec 2009
            • 3278
            #65
            Originally posted by nrubenstein
            Also, subarus don't have that great an AWD system. A lot of them are double open diffed with no traction control. In really nasty circumstances, they are basically 2WD.
            Can someone tell me wtf the point is in owning an awd car with open diffs? wouldn't that mean if one tire loses traction the car loses power to the road?
            • Mike
              • 932
              #66
              325e w/lsd > 325i w/lsd
              Supatek -noun - your basic know it all
              • u3b3rg33k
                • Jan 2010
                • 2452
                #67
                IIRC, the iX ABS system is designed to handle the AWD system, so it doesn't freak out.
                That's like asking wtf the point is in owning an open diff 2wd car. Lots of people do that...
                but for the real answer:
                I don't think they're set up that way. It really depends on the diffs and t-case setup. Eg, our explorer is open F/R, t-case center, so there is only a problem left to right, not front to back.
                • nrubenstein
                  • 3148
                  #68
                  Originally posted by u3b3rg33k
                  All that electronic nonsense does serve a purpose, but the bmws would still benefit from a non-open core. I've test driven the 335d, and 335xi in the winter, and it's very obvious when the system is operating. As I understand it, a torsen will complement traction control nicely, amplifying the efforts of the system to move power around.
                  I'm not in any way stating that I don't like having the mechanical stuff. I'm just stating that in non-performance situations, the electronic half-assery works a lot better than you'd expect.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • Bimmerman325i
                    • 6854
                    #69
                    Same for my Subaru. It's a manual trans car, so it has transfer clutches in the center diff (aka, LSD center) to apportion the power front/rear/ The open diffs only matter side to side. It's not optimal, but it works incredibly well.
                    98 M3/4/5 (stock)
                    • u3b3rg33k
                      • Jan 2010
                      • 2452
                      #70
                      Here's proof, AWD + mash gas > 2WD + mash gas
                      Because when I want to go somewhere in the rain, I drop the clutch and mash the gas.
                      • u3b3rg33k
                        • Jan 2010
                        • 2452
                        #71
                        Honestly, the SH-AWD seems like one of the best systems out there.
                        I think it's basically the same system that is in the new S4, and in the bmw active M diff. Honda's real-time AWD is one of the most useless systems.
                        What people often don't realize, is the audi quattro or hummer (torsen) system works great for these tests, IF you step on the brake as well, as that provides torque for the torsen's to bias against. I don't consider that cheating any more than I consider electronics cheating (depending on the day, my answer might change).
                        • SpoolnDaapex
                          • Jan 2010
                          • 150
                          #72
                          Do any of you disable ABS in the winter?
                          I did for the first time this winter and its much better on surfaces that have just been snowed on. The tires bite right through the snow and grab the pavement. Doesnt do much on ice covered roads though.
                          M42: Because 110 feels like 140 :finger:
                          • u3b3rg33k
                            • Jan 2010
                            • 2452
                            #73
                            My abs works exactly the way I think it should in snow.
                            • Bimmerman325i
                              • 6854
                              #74
                              That's my gen of Legacy. Awesome car.
                              98 M3/4/5 (stock)
                              • kid325e
                                • Sep 2007
                                • 6421
                                #75
                                My iX is better than any RWD car i've ever driven in the snow. Period.
                                clutchCTRL!
                                Move with a purpose.
                                - 1991 325iX 4dr/5spd
                                - 2000 323i AT
                                2016 Mazda CX3 Sport AWD
