lol
Steel oil pan?
i think this is referring to his drift eta, which is pretty dang low and driven pretty dang hard.There is a steel m20 pan, from an e28 I believe. Dont know why you would want one. Dont drive like a douche, and if you are low on the street, get a plate. Problem solved. If you are using a steel pan in place of a plate for rub and scrub, all that force will then be transfered to your motor mounts any time the pan sees contact.1989 325is / 2.7, 274 cam, e30 M3 5-lug
1989 LN106 Hilux / 3.0TD SFA
1974 2002tii / stock
2002 IS300 / 5spd LSDComment
this thread is funny. you guys must not have ever driven a fwd car made in the 80's. The steel oil pans are less rigid then the aluminum pans and bend like crazy to the point where it would break your oil pump. But last i checked they were only $20 for my VW so its pretty much a disposable design like a condom.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
Im having a guy I just met on another forum modify a 318 steel pan for my M52 turbo. He just got a job at a machine shop and thinks he can do it.
He also said he could fab all sorts of custom parts and some carbon fiber tooComment
Yea, but ive seen some non vw steel pans take a beating (see byrons car)this thread is funny. you guys must not have ever driven a fwd car made in the 80's. The steel oil pans are less rigid then the aluminum pans and bend like crazy to the point where it would break your oil pump. But last i checked they were only $20 for my VW so its pretty much a disposable design like a condom.
would they even fit on an e30?
Screw rubber! Use clear lexan! fuh raze easy oil level checking!
Seriously, though, I drive an M42. I have 3, maybe 3.5 inches from pan to ground. Knock on wood, I haven't even scraped anything yet, and I've been driving it for 2 years like this.Comment
Great idea. Like when I smacked the lower (steel) oil pan on my m10 318i and instead of just busting open like an aluminum pan would have, it folded under, taking the upper pan and oil pump with it.
Aluminum is fine. Get a skid plate if you're that worried.'84 318i - Lapisblau/Schwarz (in cryosleep)
'06 330i - Titansilber/SchwarzComment
