Rear wheel hub nut removal
  • barry
    • 1642
    Ok Guy's
    I'm trying to remove the above with great difficulty.
    Tried impact wrench 240 lbs torque, no luck
    Tried standing on breaker bar 220 lbs, no luck
    all the time using blaster liquid to try and help loosen it.
    Any ideas would be greatly appreciaiated..
    Thanks Barry
  • call me jack
    • Jul 2010
    • 425
    torch. get it good and hot that the metal expands, then impact it.
    • der affe
      Technical
      • Dec 2005
      • 8452
      What line pressure were you running the compressor at? I just pulled both of mine yesterday to do rebuilt axles, both had rust on them. I was running 120 psi and they came right off. If you are using a cheap or old gun, it can make a difference as well, if there is no oil in the gun, you will loose torque.
      Don't go toooo crazy with the heat though as you can mess up the seals in the wheel bearing.
      • mikeedler
        • 6707
        breaker bar with a cheater bar on it, and a heat gun warming it all up.
        • Wishno87
          • 6025
          +1 I just did a pair at 120 a few nights ago.
          • bzboardz
            • 1096
            silly question but did you remove the securing plate#5?
            • Adrian_Visser
              • Jun 2006
              • 2823
              ^^This^^
              '89 Alpine S52 with goodies
              • Vtec?lol
                • Dec 2009
                • 3278
                Where's the write up for this?
                • StereoInstaller1
                  GAS
                  • 22679
                  It is pulling 1 nut, why a writeup?
                  You can see the plate, it isn't hidden. Generally, hammer and punch and needlenose pliers get them out...but I generally just twist them off with an impact gun.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • Holland
                    • Nov 2008
                    • 7212
                    ^ This. After prying and pulling, I just said fuck it and twisted them out with an impact.
                    Originally posted by DEV0 E30
                    • barry
                      • 1642
                      I used an impact that was electric, no luck
                      Do you think a propane torch would work?
                      These nuts have never been off the car in 23 years.
                      • nrubenstein
                        • 3148
                        What you need is a 6' long pipe to put on your breaker bar. Electric impacts are weaksauce.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          I just reused the spacer/lock plates. I also put a LITTLE dab of red loctite on them for extra security.
                          • barry
                            • 1642
                            I found a guy with a huge impact wrench 650 torque lbs took the nut off like butter.
                            Thanks guy's
                            Barry
                            • Rigmaster
                              • 3464
                              Everyone thinks the impact is the only way- but if you don't have access to a good impact wrench, leverage is your friend. A long ass breaker bar or a cheater pipe to crack it loose, then spin it off with a ratchet or a weak impact wrench (electric/cordless/air).
                              BTW, I've found that my corded electric DeWalt 1/2 Impact isn't worth a crap for stuff like this. I can spin 20 of these things off with my Cordless Snap On 1/2 impact on one charge or just use a big breaker and they come off no problem.
