Someone please help!! Trim question
  • cmonti
    • Oct 2009
    • 133
    I know that there are a lot of threads talking about how to remove trim but for some strange reason I just can not find how to remove the trim off of a rear plastic bumper. I know there are screws that hold it in I think? But i don't know how to get to them. Someone please help or point out a thread i can read! thanks!
  • BoxDriver86
    • Jul 2009
    • 912
    There are two screws at each end cap holding the trim on. Other than that, there are several tabs running along the top and bottom of the trim along the bumper. If you have the bumper removed it should be pretty clear looking at it. If not, lookie here:
    • cmonti
      • Oct 2009
      • 133
      thanks a lot! is it something i can without removing the bumper?
      • N2MYE30
        • Oct 2007
        • 5536
        Im assuming that you took the bumpers off the car. IIRC, there are torx screws,1 on each end of the bumpers from the inside. I used a flat head screwdriver to pry the tabs off the bumper and pushed the tabs away from the bumper.
        edit: You got a quick draw there patrick. :)
        COTM
        • cmonti
          • Oct 2009
          • 133
          Thanks for the tips!
          • MaxBell
            • 1391
            The trim pops off cuz its held on with little tabs. If the bumper is still on the car, it's a little tough to not break the tabs, but if the bumper is off the car just use a screw driver to wedge out the trim.
            REMEMBER: Be safe and have fun is Rule Number 1.
            The Epic Unbuild of Clint Eastwood
            • cmonti
              • Oct 2009
              • 133
              So im guessing its easier to just take off the whole bumper and go at it from the inside right?
