coolant light
  • e30_609
    • 134
    coolant light
    my coolant light kept coming on, and i have coolant, can someone tell me why and how i can stop this
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    mine stays on even if i have a full reservoir...
    but i i have issues in my cooling system so i thought maybe it was that
    • e30_609
      • 134
      Shit mines come on and like a hour later it come on
      • gtarwiz
        • Jan 2009
        • 591
        Its probably your coolant level sensor. Mine comes on sporadically but the clip on mine is broken and any hard bumps knocks it out causing it to come on.
        BMWCCA # 482566
        Originally posted by nando
        also, I can't think of any BMW special tools you need to do a headgasket on an M20. you could nearly do it with the trunk tool kit, some bubble gum, and string.
        Check out my Leather Shift Boots for Sale Here
        Check out my other work with my GF Here Great gifts for your Wife or GF
        • accident
          • 7303
          The coolant light on the check panel is only a level light. If it's coming on and you're not low on coolant, the sensor is bad or you have connection problems.
          Moral of this story?
          • kingston
            • Jun 2010
            • 2669
            The coolant sensor on mine rotated 90 degrees downward. There is a flat edge on it that is supposed to press against a flat edge on the coolant reservoir. Check and see if yours has moved. It's a nice free fix!
            Originally posted by LJ851
            kingston is the play by play announcer for this thread.
            ‘Tis by the grace of God that my cars run!
            Originally posted by unloadedak
            #teamross
            Siobhan's Build Thread - UPDATED!
