I have a 90 325si that has just developed this problem, the odometer doesn't work, but the speedometer does. How can I determine what the problem is, and hopefully correct without spending tons. Thanks
Speedo works but Odometer doesn't
probably but it is really very simple here are the directions.
1) Remove steering wheel- be sure steering wheel is unlocked when removing otherwise it will not come off.
2) remove the two screws securing the instrument cluster bezel they are facing up toward the windshield
3) remove bezel
4) remove 4 screws securing the instrument cluster
5) remove instrument cluster
6) disconnect the connections
reverse for installationsigpicComment
buy NEW gears.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Lance Richert '88 M3, #35 PRO3, i3 etc.
www.LanceRichertArchitect.com
2019 E30 Picnic Weekend: June 22-23 2019
I pulled the cluster on my 91 without taking the wheel off. That being said I still want to get the stinkin wheel off because I need to fix my wiper switch. You can work it around the wheel without too much difficulty.
Replaced the gears with new ones, worked consistently for about 2k miles, now it works about 20% of the time. Everything else in the cluster still works. Oh well.sigpic
-Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
Removing an airbag wheel.
step 1) disconnect battery wait 15-30 minutes to make sure residual charge is gone.
step 2) look behind the steering wheel there will be two holes with Torx screws at the bottom, unscrew them they will not come out leave them in there.
step 3) while performing step 2 make sure to hold airbag so it wont fall on the ground
step 4) pull connector off of the airbag
step 5) place airbag in a safe place and make sure it is situated in a way that if it does go off nothing will be shot across the room including the airbag itself.
then proceed with above said directions.sigpicComment
all this but do not connect your battery back until the steering wheel is in place and secure. otherwise you will get the SRS warning forever moreRemoving an airbag wheel.
then proceed with above said directions.'87 325ic, powered by S50.Comment
I just re wired my differential wire, then it started working.
But the above statements sounds more likely.
Fast life fuck slow..Low life for life
Let the mix flow..Let the night flow
I'm so gone ✗ ♥ OComment
