318 with m20 swap
  • gotEdirty?
    • Dec 2010
    • 11
    318 with m20 swap
    I just picked up a 91 318is that has an m20 from a 325is
    I don't know if the cluster was swapped or maybe the rear end gears, but it's revving extra high. 4500 rpm cruising at 70mph
    Any ideas?? Thanks
  • Rsully70sev
    • 2391
    Any ideas?? Thanks
    At 70mph I'm usually doing 3k.
    I've got an m20 with the "I" head, and 3.73 gears. The only reason you'd be reving so high is if you had a 4.10 diff or if they didn't change the cluster (imo) I'm sure someone else will have some insight.
    • Vtec?lol
      • Dec 2009
      • 3278
      at what rpm does it idle?
      • xwill112x
        • Jan 2009
        • 4236
        the coding plug in the cluster is for a 318 then i would assume
        • gotEdirty?
          • Dec 2010
          • 11
          It idles at 900ish. I've been told it could be the 4.10 gearing. How would I know what cluster is in it? I can't get ahold of the guy who did the swap. Thanks for the ideas!
          • Vtec?lol
            • Dec 2009
            • 3278
            does it say motometer?
            • gotEdirty?
              • Dec 2010
              • 11
              No not that I know of
              • gotEdirty?
                • Dec 2010
                • 11
                Yes it does say motometer! And also k7784 sae? Let me know if you guys know anything thx!
                • K04A1
                  • Nov 2008
                  • 5
                  Car still has the stock 4 cyl cluster. 100% sure.
                  • ZekeTheSneak
                    • 1562
                    Coding plug, Had to swap it on my Swap.
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      70 mph should be right around 3600 revs with a g240 and a 4.10 diff, iirc.
                      Project M42 Turbo
                      • Brandon12V
                        • 1318
                        hmm.... If it was the diff, I would have imagined this very easy to tell by the sound of the motor, lol. 3600 sounds about right for 4.10 gearing. I'm at 3k+change @ 70mph with my 3.73lsd. Then again, I dont know how different the gearing is between the g240 & g260(what I have).
                        Originally posted by Ryan...
                        It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
