Official Fabrication & Welding Porn Photo Thread
  • der affe
    Technical
    • Dec 2005
    • 8452
    #241
    next i started making a fire pit for the back yard
    base and sides all tacked together
    frame done
    tacking the feet on. the feet are 2 1/2", 1/8" wall (squared and trued in a lathe) with 3"x3" 12 gauge squares welded to them.
    a little more progress and more welding.
    bottoms of the sides fully welded, the frame stitched on the insides.
    feet welded on, inside stitched.
    good stopping point until next weekend
    next weekend i will finish welding it and cut the bottom for 2 3"x4" squares of perforated 10 gauge steel for convection. i also need to make the filler pieces for the gaps in front of the legs.
    i "might" start hunting for a propane bottle, burners and lava rocks to put in it after i burn up the wood i have (i have about 1/3 of a cord from my mesquite tree in front of the house)
    the specs are:
    19" base
    10" sides set at just under a 45* angle
    over all OD
    height
    i might start on a second one for a friend also.
    i will post up finished pics next weekend.
    NEXT: i am going to start on a new park bench for the front entry way of the house.......over built of course. :D
    • der affe
      Technical
      • Dec 2005
      • 8452
      #242
      i also needed a new recycle can that was bigger than what i had been using, so i made this up and had it powder coated with the tables.
      it is made of 12 gauge steel drops. i have a friend who owns a water jet company and he lets me have the drops (which are the left overs after the shapes have been cut out of them. pretty much scrap)
      i still need to make the liner that drops in out of aluminum, so for now the old recycle can sits inside of it.
      • F34R
        sLaughter
        • 12390
        #243
        God help the person that falls on that fire pit corners haha. Looks great though Greg. LOVE the waste basket, needs a white trash bag to make the holes pop.
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
        • der affe
          Technical
          • Dec 2005
          • 8452
          #244
          i will give the corners a nice radius when i am done.
          the trash can will have an aluminum liner that will lip over the top with aluminum C channel and have a satin finish to give better contrast. the plastic bag liner will go inside of that.
          your table thread go me thinking about needing a nicer set of tables for the patio. i suck at wood working though and i knew the steel would hold up to abuse and neglect better than wood.
          • jaywood
            • Jul 2010
            • 4528
            #245
            Those furniture pieces look nice. I like it!
            • myE30rules
              • Sep 2011
              • 13
              #246
              there is some serious talent in those photos
              • JGee
                • Jul 2011
                • 264
                #247
                Right on! Good looking stuff.
                Digging the stash box in the end table.
                Thats the kind of furniture that will still be around when the grandkids are looking to bend some ass over it.
                HIK Fab
                • JakeP
                  • 315
                  #248
                  The thread on my desert truck site has been going since 2009. ONLY CLICK IF YOU HAVE HOURS OF FREE TIME!!!!! (140+ pages)
                  http://www.race-dezert.com/forum/sho...tty-Welds-****
                  • AndrewBird
                    The Mad Scientist
                    • 11892
                    #249
                    More parts from work:
                    BIG driveshafts for a prototype airplane. All out of stainless. Tube diameter is ~4".
                    Before and after one operation. The "shaft" runs at an angle through the center part, so it took over 30,000 lines of code and ~30 minutes to run.
                    Seatbelt mount for an airplane. Notched to fit onto two intersecting bars.
                    3-station setup running aluminum soft jaw blanks.
                    TubeShark dies.
                    Velocity stack.
                    Sanding block I made in my free time at work.
                    • AndrewBird
                      The Mad Scientist
                      • 11892
                      #250
                      Oh, and this is what happens when a 3/4" endmill spinning at 14,000 RPM hits solid aluminum at 120 inches per minute. Took about 1/2 a second to do that and sounded like a train horn. Would have kept going had I not stopped it.
                      • evandael
                        • Oct 2009
                        • 2881
                        #251
                        ^ yikes... any spindle damage on that one?
                        • AndrewBird
                          The Mad Scientist
                          • 11892
                          #252
                          None what so ever. Endmill was fine as well.
                          • tinkwithanr
                            • Jun 2010
                            • 377
                            #253
                            In that case buy some earplugs and crank up the feed!
                            But in all seriousness those are some great looking parts. How many axis (axi ?) are your machines?
                            Tinker Engineering - 2014
                            Mica - 2000 BMW 323i - The one that started it all
                            Fiona - 1975 BMW 2002 - The Definition of Project Creep
                            Heidi - 1988 BMW M5 - The piece of BMW history
                            Silvia - 2013 Subaru WRX - Stock, for now
                            • AndrewBird
                              The Mad Scientist
                              • 11892
                              #254
                              We have two 3-axis mills, one 3-axis with a rotary table, a two axis lathe and a 7 axis lathe/mill combo. Then a bunch of manual machines and a waterjet. Oh, also a 5 axis CNC press brake. Website is here:
                              • AndrewBird
                                The Mad Scientist
                                • 11892
                                #255
                                Made these at work tonight:
                                Made them from scrap, so they were completely FREE.
