Hydrochloric Acid anyone?
  • lolcantturn
    • 4588
    My friend and I have an almost unlimited supply of this stuff. We added 50% water to a chemical bucket, then 50% of that stuff, followed by another bucket with nothing but soap to stop the reaction. We tried cleaning my motor arms since they were gunked to shit, but it ended up pitting the metal. Then we took an old rusty tool and dipped it in, and it got rid of all the rust and looked awesome, but it also wore away the zinc coating and now it's even more rusted to shit.
    Any way of actually producing good results with this stuff?
    Originally posted by TSI
    OEM+
  • JakeP
    • 315
    Try a 5% solution next time.
    • mrsleeve
      • Mar 2005
      • 16387
      that
      we used to use about 8-12% solution to scrub all the shit off aluminum hulled boats
      Originally posted by Fusion
      William Pitt-
      • lolcantturn
        • 4588
        So 5% HCl, 95% water?
        I've got a lot of parts to clean ;)
        OEM+
        • 5Toes
          • 9836
          Where you getting it?
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            I'm thinking someone is boosting from their HS Chemistry closet.
            • lolcantturn
              • 4588
              You can get it from any pool supply store
              OEM+
              • Dibs
                • May 2011
                • 4
                I've used something called Milkstone Cleaner - available from any Diary Supplies place. It's Phosphoric Acid. Diluted down to 15%, works wonders!
                With any acid - it will eat the oxide, which would result in pitting tho.
                HIH
                Dibs
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Generally called Muriatic Acid in that form. Same thing, different name. Hardware stores will generally sell it too. I use it occasionally to etch circuit boards.
                  • AbsorbantNut
                    Non faccio funzionare questa merda
                    • Jun 2010
                    • 2491
                    i use it in pools?
                    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                    • Click
                      • 637
                      Common name for HCl is muriatic acid.
                      ส็็็็็็็็็็็็็็็็็็็็็็็็็
                      I need you to exfoliate my ballsack
                      Build Thread?
                      • sergio318is
                        • 163
                        yes I work for pool company. when use it to was the plaster in pools of the winter if they get stains from leaves or whatever else gets under the safety cover.
                        had a gallon spill in van over day was pulled over on high way van smoking like crazy lol.
                        Sent from my PC36100 using Tapatalk
                        • lolcantturn
                          • 4588
                          that smell must have killed you.
                          OEM+
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            I think it is generally used with pools to adjust the pH of the water, not clean stuff.
                            • Ryann
                              • 3350
                              Poor some (undiluted) into an empty 2 liter soda bottle, stuff some aluminum foil in there, put the lid on tightly, and RUN!
