Head work
  • downernsp
    • Mar 2008
    • 1932
    Head work
    So I figured out the hard way on how to time the engine. I bent a valve woohoo time for a rebuilt head. Ivwill be doing a billet 272 now with hd rockers and a porte job.
  • kingston
    • Jun 2010
    • 2669
    How did it happen?
    Originally posted by LJ851
    kingston is the play by play announcer for this thread.
    ‘Tis by the grace of God that my cars run!
    Originally posted by unloadedak
    #teamross
    Siobhan's Build Thread - UPDATED!
    • lolcantturn
      • 4588
      Learned the hard way as well. You have to hand crank the motor before even thinking of turning that starter over.
      Originally posted by TSI
      OEM+
      • downernsp
        • Mar 2008
        • 1932
        I was changing timing belt and I moved crank with belt now wraped around cam gear. Then when I went to adjust cam to be inzic with crank I must of not lined it up correct. Cranked then engine heard a backfire in throttle body. Stopped cranking it went to sleep since I was tiered called a budy for help. Turned crank by hand and it jamed up wright before tdc. Opened valve cover 1 intake was lifted with lobe engaging hence bent valve.
        • kingston
          • Jun 2010
          • 2669
          Any progress? Thinking about camming the engine and getting HD IE rockers. Looks like they're on backorder currently, though..
          #teamross
          • CleanAzzE30z
            • Jan 2004
            • 11794
            Nice job, Flavio.... ;)
