Quick 02 sensor question, need help!
  • AirplaneBuilder
    • 823
    What type of wire would I use to extend my 02 sensor wires, can I use same type of wire for the black, grey, white wires or are they all different? I got headers installed and the stock wiring is way too short now. I need to pass smog test and can't have my check engine light on to try test. Any help would be much appreciated!!
    1989 Zinno 325i S50 ZF320
  • der affe
    Technical
    • Dec 2005
    • 8452
    the same gauge as the sendor's already existing wires.
    if they are the ebay headers, you will need to extend the about 2-2.5 feet.
    • AirplaneBuilder
      • 823
      Ok Same gauge, but what about the wire type? Copper wires? Some ppl say its stainless steel wires..... can someone confirm?
      • bimmer630
        • 1228
        Get an old faulty sensor and use the wires from that if youre super concerned of the makeup
        • AirplaneBuilder
          • 823
          • bimmer630
            • 1228
            And i think on 325E's they used a longer sensor, with a further back location in the pipe. check into that, i dunno if the E motor sensors will work with the I computer
