1988 BMW 325IS sitting for 3 years where to start?
  • jaydeep
    • Jun 2011
    • 208
    I have 1988 BMW 325IS sitting in garage for 4 years. Car does not start anymore tried jump start. Car was running and driving 4 years ago.
    My question is where should I start? Which step should I follow?
    Thanks
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
  • Massimo
    • Jan 2008
    • 3207
    Chainge oil and water, new spark plugs and leads. Clean distributor, give alternater a few light hits wit a rubber mallet, drain fuel and replace, oh and new battery.
    Should start then.
    • colorado_cabrio
      • Sep 2009
      • 891
      fluids
      • ill4noreason
        • 2710
        Change oil, Flush coolant ,air filter, tune up, drain gas tank completely flush it then add dry gas and run high octane 1st tank. Take a good battery from a running car try then... If you get it running I would drain trans fluid, gear oil, brake fuid complete flush, after sitting that long.
        My Multi car part out. Need a part? Pm me...
        http://www.r3vlimited.com/board/showthread.php?t=193051
        Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
        http://www.r3vlimited.com/board/showthread.php?t=215044
        Have you done business with me? If so leave me feedback here...
        http://www.r3vlimited.com/board/showthread.php?t=188307
        • M-technik-3
          • 18946
          Coolant as well.
          • Julien
            • 7471
            peak inside the gas tank to make sure it hasn't rusted up or turned into varnish in there.
            Build Threads:
            • Mossman
              • Apr 2006
              • 1961
              Jump pin 87 and 30 on fuel pump relay, see if it's humming. Pull a plug and put it in its wire, ground side of plug to block and have buddy crank. Look for spark.
              • kingston
                • Jun 2010
                • 2669
                Do the timing belt! I suppose you're question was simply what to do to get it started, but it would suck to get it started, and then destroy the engine from an old timing belt that's been in the same position for 4 years!
                Originally posted by LJ851
                kingston is the play by play announcer for this thread.
                ‘Tis by the grace of God that my cars run!
                Originally posted by unloadedak
                #teamross
                Siobhan's Build Thread - UPDATED!
                • M-technik-3
                  • 18946
                  Might already have a snapped belt who knows it's an estate sale. Also that's a decent AAA ride back on a flat bed. There was no mention in the ad if it was standard or automagic.
                  • kingston
                    • Jun 2010
                    • 2669
                    Well, that's a good (if depressing!) point, too!
                    #teamross
                    • BDSax
                      Junkyard King
                      • Mar 2006
                      • 3594
                      fuel pump is probably shot
                      • jaydeep
                        • Jun 2011
                        • 208
                        guys it seems like car is not getting gas. Do you guys think old gas might be problem?
                        I tried to put gas in intake (after the air filter) then car wanted to start till I put gas in intake.
                        Please help me out
                        • UNHCLL
                          • 8790
                          Apparently nobody thought to suggest cleaning the fuel injectors.
                          Chances are after 4+ years they are clogged/stuck closed.
                          Below the radar...
                          • Heysüß
                            • 911
                            Originally posted by unhcll
                            apparently nobody thought to suggest cleaning the fuel injectors.
                            +1
                            09/1989 325i 4 Door
                            +M30 Swap
                            +Z3 Steering Rack
                            • mikeedler
                              • 6707
                              pull the line off the furel rail while your cranking it and see if fuel spits out.
                              if yes and it doesnt start, have someone spray some starting fluid in the aircleaner while your cranking and see if it starts. if it runs then, the injectors are stuck. if no start, it could be a 100000000000 things.
